disable cli space-completion
Description
Disables the ExtremeXOS feature that completes a command automatically with the spacebar. If you disable this feature, the [Tab] key can still be used for auto-completion.
Syntax Description
Default
Disabled.
Usage Guidelines
None.
The following command disables using the spacebar to automatically complete a command:
Platform Availability
